Waeco SMPS
Discussion in 'General Electronics Chat' started by debe, May 3, 2011.
  1. debe
    Sep 21, 2010
    955
    185
    This is a SMPS for a Waeco portable Fridge Freezer, My question concerns D7 which is a BYV32E-200 dual diode 200V @ 20Amp. This is the rectifier for the 24V DC side, can it safely be replaced with a 60V @ 20Amp dual diode. The 60V diode is easier for me toget thinking 200V is an over kill?
  2. tom66
    May 9, 2009
    2,613
    214
    Not necessarily. It could be rated at 200V to compensate for spikes due to the SMPS's switching action. Replace only with an identical or equivalent part, as the failure of that component (failing closed) could be bad for the other secondary side components.
  3. kubeek
    Sep 20, 2005
    4,687
    805
    60V is on the verge of breakdown, the diode will have to block 2x the ouput voltage, which is quite close at 50V. I would use a diode reated for 100V.
  4. debe
    Sep 21, 2010
    955
    185
    Thanks for that insight guys, think il play it safe & use the 200V diode.
  5. JonnoP
    Jul 25, 2012
