VU meter
Discussion in 'The Projects Forum' started by cmsch180, Jul 3, 2008.
  1. cmsch180
    Jun 26, 2008
    12
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You'd be far better off using an LM3916, because it's designed for use as a VU meter.
    The LM3915 is logrithmic, the LM3914 is linear.
  3. cmsch180
    Jun 26, 2008
    12
    ok thanks, i already had the LM3914 so i was just wondering
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I suppose that you could use it, but you would have to pre-process the input, perhaps using an opamp and associated components. It really would be more trouble than it's worth.
    Jameco.com has LM3916N/NOPB's available as 4-day dropship for $1.59 each. They don't have a minimum buy.
    Save yourself the hassle of trying to beat a square peg into a round hole. Unless, of course, you really want to tackle something like that, and don't mind spending lots of time fiddling with it.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    I designed a Sound Level Indicator project with an electret microphone, a preamp and an LM3915 driving two LEDs in series on each output. The LM3915 has a logarithmic detector like your hearing and I enhanced it 20dB with a simple compressor circuit when sounds get loud. So it is extremely sensitive and shows a pin dropped on the floor of the next room and also shows very loud sounds.
    An LM3914 is a voltmeter. It does a poor job measuring sound levels.
  6. cmsch180
    Jun 26, 2008
    12
    ok thanks guys
