VU meter teardown - not what I expected
Discussion in 'General Electronics Chat' started by andrew331, Feb 15, 2016.
  1. andrew331
    Apr 28, 2015
    14
    Hi
    In a box of parts that I will most likely newer use I have some VU meters, old analogue types that used to be very common in audio equipment.
    I decided to have a look inside one.
    What I expected to find was:
    'The original VU meter is a passive electromechanical device, namely a 200 µA DC d'Arsonval movement ammeter fed from a full wave copper-oxide rectifier mounted within the meter case.'
    The meter movement was as expected but no sign of any rectifier!
    Could anyone explain this?
    Andrew
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    Not without some photos...
  3. andrew331
    Apr 28, 2015
    14
    I damaged the meter taking it apart, so the bits are no in the bin!
    I am thinking it may have needed some external components? Diode?
  4. SLK001
    Nov 29, 2011
    852
    243
    Or, the meter could have been de-linearized using weights around the movement.
  5. Nykolas
    Member
    Aug 27, 2013
    93
    31
    VU meters on consumer stereo equipment was sexy, but not Vu. These meters are standard mV movements. A rectifier and a RC network (of varying complexity) would simulate the ballistics of a true VU meter. E
  6. RichardO
    May 4, 2013
    1,350
    432
    A moving vane meter, maybe?
  7. DickCappels
    Aug 21, 2008
    2,786
    676
    (Emphasis added by me)
    You stated that the movement was fed by a full wave copper oxide rectifier inside the case . I think you answered your question before you asked it.
  8. SLK001
    Nov 29, 2011
    852
    243
    He stated that this is what he expected to find. He did not find what he expected, so was wondering how a linear movement was made non-linear.
  9. DickCappels
    Aug 21, 2008
    2,786
    676
    Thank you, I misread the original post and understand, he was talking about the prior meter.
    In that case I endorse Nykolas's explanation in post #5.
  10. andrew331
    Apr 28, 2015
    14
    Thank you all.
    Nykolas was right, these are not proper VU meters, just regular dc meters that need some external circuitry.
  11. alfacliff
    Dec 13, 2013
    2,449
    428
    a lot of VU meters on consumer devices use an external rectifyer and rc filter to simulate the non liinear charistics of a coper oxide rectifyer to give a logarithmic scale. your meter just does not have them inside.
