VRV went BANG ! Caught fire.
Discussion in 'General Electronics Chat' started by R!f@@, Apr 21, 2015.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,791
    771
    I thought this would be interesting to show.
    Yesterday attended a VRV and here is what I found.
    Nice huh.!!
    Check out the capacitors:D
    I need to rewind the inductors though....any idea how should I go about it ? :confused:
    DerStrom8 likes this.
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    What's a VRV?
  3. tom_s
    Member
    Jun 27, 2014
    287
    342
  4. pwdixon
    Member
    Oct 11, 2012
    488
    56
    I tried Google but it didn't look relevant....
  5. Dodgydave
    Jun 22, 2012
    5,154
    772
    is a Vrv an air conditioning unit...
  6. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Google says yes but since the OP "attended a VRV" it could be something else.
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    I think he meant "attended to", as in worked on or tried to repair or something like that.
    ak
  8. R!f@@
    Apr 2, 2009
    8,791
    771
    I am fixing an AC unit. VRV type, which the compressor unit is on top of the building.
    It is an inverter type.
    Is it a slow blow a quicky. I cannot tell from the part number. It does not state it as a slow blow.
    U mean the compressor ??
  9. tom_s
    Member
    Jun 27, 2014
    287
    342
    was under the assumption sand filled fuses were slow blow and with a 20a rating, startup would be pulling close to that.
    is there a motor attached to that compressor? :)
  10. R!f@@
    Apr 2, 2009
    8,791
    771
    The compressor is 3 phase motor. You know inverter drive the VFD type.
    The only surge will be the caps initial charge current I think
  11. R!f@@
    Apr 2, 2009
    8,791
    771
    I have question about the inductor winding.
    The inductors are for EMI filtering.
    Each one has 4 isolated winding, 1 for each phase and 1 for neutral. 4 in total. Both inductors are in series.
    I need to wind just one. I unwound one and it has 15 turns. Due to the winding is I cannot tell the start or end but I know the direction.
    What would happen if I get confused in start and end of the winding ?
    Should all the winding be same direction or not ?
  12. DickCappels
    Aug 21, 2008
    2,773
    669
    If you have not already removed the wire from the core, you can merely note the directions of the windings with respect to one-another.
    R!f@@ likes this.
  13. R!f@@
    Apr 2, 2009
    8,791
    771
    I guess It's fair to tell this VRV is fixed and running now
  14. ronv
    Nov 12, 2008
    3,401
    1,458
    That's what the electronics fairy does. She waves her magic wand over a circuit and it goes poof I'm a pile of s**t.
    cmartinez and #12 like this.
  15. ian field
    Oct 27, 2012
    4,447
    791
    It certainly seems to have got well stuck into venting things.
  16. ian field
    Oct 27, 2012
    4,447
    791
    If you were a radio ham making an RF balun, you'd do a bifilar or trifillar winding by twisting 2 or 3 wires together and wind them on as if it was just one wire - but I suspect you'd run into insulation problems doing that with 3 phases and earth.
    You may be able to get PTFE wire, the insulation is good enough to be thinner and still do a lot better than enamel coating.
  17. R!f@@
    Apr 2, 2009
    8,791
    771
    I did say it is working now.
