vrms output
Discussion in 'Homework Help' started by joka2188, Nov 16, 2006.
  1. joka2188
    Nov 10, 2006
    9
    i've been given this question, i know to get the vrms voltage using the peak voltage but hot would you go if u r jus given resistor values, pls have a look at the attachment and get back to me, much appreciated
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Don't see the problem. You calculate the gain using the values of R1 & 2, and apply it to the signal voltage. You're always using rms values. (Hint: the op amp configuration is a buffer with gain)
