VRLA AGM - Battery Charger
Mad Professor
Joined Apr 15, 2009
133
Good Day All.
I have got a pair of VRLA AGM batterys taken from a broken mobility scooter.
A quick google search gave me a link to good old wikipedia.
VRLA: Valve Regulated Lead-Acid.
AGM: Absorbent Glass Mat.
The batterys are made by Haze but the lable with the model number is missing.
The only thing I can tell you is that they are both 12v batterys, and aprox 195x130x160mm (WxDxH).
On the side of the battery it has a lable saying.
Battery Charging
Float Application: 2.27 to 2.30 vpc @ 20 Deg C.
Cycle Application: 2.35 to 2.40 vpc @ 20 Deg C.
As this is a Lead-Acid type battery can I use a standard car 12v Lead-Acid battery charger, or will I need a battery charger designed for this type of battery?
Thanks for your time.
Best Regards.
Smoke_Maker
Joined Sep 24, 2007
126
A 12 volt battery charger will work but don't let it go over 14.8 volts, keep a eye on it with a volt meter. You can find a inexpensive charger at auto parts or sears or kmart that has AGM setting on it.
Externet
Joined Nov 29, 2005
2,227
2.40 vpc means volts/cell; which adds up to 14.4V maximum. 14.0V should be a safe margin to charge them, and a plain decent car battery charger should be able to regulate that.
To leave the charger connected long times, 2.28vpc adds up to 13.7V
It is good you have the charging recommendations from the manufacturer.
SgtWookie
Joined Jul 17, 2007
22,230
Note that the temperature is also specified for the vpc.
Lead-acid batteries have a negative temperature coefficient that's roughly 3mV per cell per degree centigrade; since you have six cells per battery, that's 18mV per degree centigrade.
Note that charging at high current levels will increase the internal battery temperature. It takes a very long time for a battery to cool off once heated.
Mad Professor
Joined Apr 15, 2009
133
I have a RAC HP026 Lead-Acid battery charger for my car.
I am able to select fast or trickle charge.
Fast Charge = upto 8amps @ 12volts output.
Trickle Charge = upto 2amps @ 12volts output.
I have not tested the charging voltage with my DVM.
Would it be best to just use the Trickle Charge.
Best Regards.
studiot
Joined Nov 9, 2007
4,998
So long as you control the charging manually either would work.
However I would not run at the 8 amp level for more than 30 minutes at a time as you can boil the fluid and bend the plates through overheating.
So the 2 amp rate is safe unattended overnight, the 8 amp rate is for boost. I expect it says something similar in your charger manual.
You should realise that you can only charge one of your batteries at a time with your charger? If you try to charge the pair in parallel the current probably won't distribute evenly.
Here is a thread with a discussion about more sophisticated chargers.
http://forum.allaboutcircuits.com/showthread.php?t=16711&highlight=charging+lead+acid+batteries
SgtWookie
Joined Jul 17, 2007
22,230
Using the trickle charge would minimize the internal heat buildup.
Getting a battery hot reduces it's lifespan due to greatly increased chemical activity.
You can measure your battery's internal temperature by the positive terminal. If you decide to try the fast charge, I suggest monitoring the battery internal temperature, and reduce the charging rate once the temperature has increased.
Here's a chart for you; charge and float voltages over temperature for your particular batteries.
