volumes of revolution ...help!!
Discussion in 'Homework Help' started by oussama123443, Nov 27, 2015.
  1. oussama123443
    Nov 2, 2014
    27
    hey guys...!! what is the volume of the solid when rotating the areas between y=(x^3)-x and the x-axis around the line x=1 ???
  2. djsfantasi
    Apr 11, 2010
    2,905
    878
    Hey Oussama,
    Does the solid extend into infinity? At what points along y=x^3-x and x=0 (if at all) does the solid end?
    oussama123443 likes this.
  3. oussama123443
    Nov 2, 2014
    27
    no boundaries were given for the integral , the function has x=1 and x=-1 as roots so i'm trying to figure if the shape generated will be from " -1 to 1"
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    The bounds are definitely important and they are not at all obvious.
    What about the root at x=0?
    I would recommend giving your answer in three parts. First, figure out the solid of revolution between each adjacent pairs of roots and then also give the sum of them. In addition, provide an explanation why you are using those limits as opposed to something even broader.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    MOD NOTE: Moved to Homework Help from Math.
