The Electrician
- Joined Oct 9, 2007
- 2,971
Here's what I get using both formulations and both values of R:
Check your units.I thought I'd try to solve the problem using the Cartesian System ...
Unfortunately I can't produce the same answer given earlier.
I have the "solution" as the integration shown below ...
\(\text{V=\int^{+1}_{-1}\{ \frac{(R^2-x^2)}{2}\[\pi - arcsin\(\sqr{\frac{12-x^2}{R^2-x^2}}\)\]+\sqr{12-x^2} \} \ dx \ = 39.7385 \ cu. \ units}\)
Did anyone else try the Cartesian approach?
Thanks for the "heads up" on the units. Although it looks dubious, I believe the "discrepancy" lies in my having partially substituted some constant (linear) dimensions specific to the problem during the formulation of the result.Check your units.
Thread starter | Similar threads | Forum | Replies | Date |
S | Volume fade. | Technical Repair | 5 | |
S | Wheel Potentiometer to Digital Potentiometer Volume Control | Analog & Mixed-Signal Design | 0 | |
Inspire M4500 subwoofer - how in increase volume level | Technical Repair | 0 | ||
Sphere Volume | General Science, Physics & Math | 19 | ||
M | Volume of a sphere | General Science, Physics & Math | 4 |
