Volume control question
Discussion in 'General Electronics Chat' started by FMROB, Dec 3, 2009.
  1. FMROB
    Dec 3, 2009
    Hello all, I have a need to control the speaker volume of a two way radio project.
    The radio puts out about 13 watts with a 4 ohm speaker, and about 7.5 watts with a 8 ohm speaker.
    I need to know what size potentiometer to put in line to control volume almost to the zero audio point.
    Right now I am using a 25 ohm 3 watt rheostat and it is not working very well.
    The caveat is I need the control to be small in size.
    Thanks, Rob
  2. FMROB
    Dec 3, 2009
    Bump to the top
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you wish to attenuate the output to the speaker, you will need a L-pad.
    Audio volume controls are normally placed at the input of the power amp (or output of the preamp, depending on how you wish to view it).
  4. FMROB
    Dec 3, 2009
    Thank you for the quick reply, any specific type of L Pad rating?
    Thanks, Rob
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It has to be able to dissipate the power to the speaker. 15 watts sounds to be enough.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    There is nothing that says that the transceiver has to be terminated into either 4 or 16 Ohms, so why not use a higher impedance L-Pad so the L-Pad does not dissipate much power...
