hi i just made my first project with the tda 2003.But i dont know were i must put the pot so i can control tha volume.I used this schematic.
This was wrong.C1 to pot terminal 1, pot terminal 2 (wiper) to pin 1, pot terminal 3 to ground will work. What's the TDA amplifying??
If the pins according to what I linked and you doing that then when you turn to the left side, the sound will be loud, turn to the right side the sound will be weak.so
1->in
2->c1
3->ground
right?
Why you want to use LM386 as an op-amp?no prob,i like it this way
can i use this as an op-amp?
by Jake Hertz
by Duane Benson
by Duane Benson
by Jake Hertz
