Hi all
I'm currently working on a fairly simple circuit design project and have an idea which i'm not quite sure how to implement.
backgournd: - I have a amplified signal coming from a oscillating schmitt-trigger going to a small 8ohm speaker. Idea is to create a simple alarm.
I want to start with a soft beep which gradually builds louder and louder as time increases.
Signal is run by a 3v source controled by a switch, and using a 74HC14 low voltage CMOS Schmitt-trigger
If anyone has any ideas as to how i may be able to implement this in a fairly simple way as circuit size and components need to be kept to a minimum.
Thanks in advance for any help or advice.
Cheers
Cheers
