Volts regulator with digital readout help
Discussion in 'The Projects Forum' started by CamdenCircuits, Mar 11, 2015.
  1. CamdenCircuits
    Mar 11, 2015
    Hi all. Working on a project with my dad and we need a little help. Looking to build a module that can regulate wattage or volt output with a digital display that shows battery gauge and ohm readout. Sounds complicated and I realize there will be a bit of programing involved. Any and all help is greatly appreciated. Thank you in advance
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    Close enough but not quite there yet. You have to tell us what you are trying to do.
    Are you trying to display the voltage of a battery and the current drawn?
    You can do that with a voltmeter and an ammeter, analog or digital. No programming required.
  3. #12
    Nov 30, 2010
    16,704
    7,351
    That sounds like you need a voltage regulator, a digital display, some way to interpret battery voltage, and what do you want to read the ohms of?
  4. CamdenCircuits
    Mar 11, 2015
    Building a homemade vaporizer modbox. Basically a box that has a battery and a firing button. The regulator would have an output to a 5 10 connector and the readout would have two buttons that adjust the volt/wattage output to the 5 10 connector. The readout should display watts/volts, battery life, and ohms. Battery would have a charging port
  5. Dodgydave
    Jun 22, 2012
    5,155
    772
    Do you want to make a variable power supply with a battery, or are you trying to monitor the battery load?
  6. CamdenCircuits
    Mar 11, 2015
    A variable power supply. I've made one that is analog where u turn a knob to adjust the output but I'm trying to figure out how to make one that is digital.
  7. Dodgydave
    Jun 22, 2012
    5,155
    772
  8. MrChips
    Oct 2, 2009
    12,636
    3,455
    Then what you need is a variable voltage power supply with current limit adjustment.
    Voltage and current are not independent. You set the voltage. The current will be dependent on the load.
    You set a current limit. If the current limit is reached then the voltage will be reduced to accommodate that current.
  9. CamdenCircuits
    Mar 11, 2015
    Dodgydave likes this.
