Volts and Amp with one Panel Meter
Discussion in 'General Electronics Chat' started by mazur50, Feb 5, 2007.
  1. mazur50
    Feb 5, 2007
    28
    I am looking to hook one PM-128 panel meter to my power supply.
    What i would like to do is make the Panel meter read both volts and amps.
    I was also told that this can be done with out a shunt.
    What i want to do is have a switch so i can switch from volt to amps
    I would like to do somthing like this
    http://www.thegmlenterprises.com/id16.html
    thanks
    for the help in advance thanks
    Mike
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  3. mazur50
    Feb 5, 2007
    28
    Is there any way to do this with out a shunt.
    I currently have a power supply that has a meter like a pm-128 meter with no shunt. But i dont know if the meter is set as a volt meter or not let me know if you have any other idea.
    also thanks for the like i might still do that just looking for other ideas as well.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What's the magnitude of the voltage and current you need to measure? What is the precision you need to have?
  5. mazur50
    Feb 5, 2007
    28
    I would say no more then 12v and no more then 12amps maybe more like 10amps
    thanks mikes
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    A shunt is just a resistor in parallel. It provides a second path for a calculated percentage of the current, therby allowing accurate scaling and protecting the meter movement from overcurrent.
    Is there a particular reason for the "no shunt" requirement in this application?
