voltmeter
Discussion in 'Homework Help' started by akifnadeem, Nov 6, 2010.
  1. akifnadeem
    Apr 9, 2010
    15
    A 2 k-ohm resistor is connected in series with a 4 k-ohm resistor and a 1.5 V battery of negligible
    internal resistance. Calculate the voltages across the two resistors. Calculate the voltages
    measured across the two resistors by a voltmeter with an internal resistance of 2k-ohm.?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Don't expect the solution. Show your work as someone can help you.
  3. retched
    Dec 5, 2009
    5,201
    313
  4. akifnadeem
    Apr 9, 2010
    15
    i know what you want to say...!! i know voltage divider rule, but point is: when you measure voltage using voltmeter, you get the different answer. Just tell me the procedure how to figure it out. please show me the method, i know that there is internal resistance, but how does it come out different,mathematically.
  5. mik3
    Feb 4, 2008
    4,846
    63
    The internal resistance of the voltmeter is calculated in parallel with the resistor which the voltage is measured across.
  6. akifnadeem
    Apr 9, 2010
    15
    sir, kindly solve the numerical-problem that i posted, and please show me the method, that how would you get the answer.
  7. shteii01
    Feb 19, 2010
    3,507
    512
    You have three circuits here. First you solve circuit in Figure 1.
    Then you solve the other two circuits.
  8. akifnadeem
    Apr 9, 2010
    15
    thanx man...!!
  9. johncurran94
    Nov 10, 2010
    I =1,5volts/6k
    therefore voltage across 4k is 1.5volt*4k/6k and voltage across 2k is
    1.5 volt*2k/6k the voltmeter should not have internal resistance of 2k unless this is a quiz
