I have this panel voltmeter to measure a small 12vdc stereo I made. I don't have instructions with it but I found photos on Virtual Village's website. I can get it to read out 0.00 when I hook it to a 9v power supply but then when I attempt to read a 12vdc battery the leads start to heat up. The read out does change but does not measure the voltage. I'm surprised it still lights up at all since it's been heated up during a few attempts now. I'm trying to figure out the correct dip switch configuration before I fry it to death. I'm assuming the dip switch is used to adjust the voltage range it measures and is the key to my problem.
Does anyone have this meter and/or know the dip switch config to make it work to measure a 12vdc source?
I've tried 1:On / 2-5:Off and 1&5:On / 2-4:Off
Thank you!
Thank you!
