Voltmeter / circuit question
Discussion in 'The Projects Forum' started by russpatterson, Oct 25, 2011.
  1. russpatterson
    Feb 1, 2010
    351
    16
    If test voltages with a volt meter when either the fuse on this circuit is blown or ground is not connected to the battery, then I read the 12V battery voltage on both the input of the 7805 voltage regulator and the output. I don't really understand why this is so but it must have something to do with the meter ground being connected to the battery ground.
    If the fuse is good and the board is connected to the battery ground then everything reads fine (e.g. 5V on the 7805 output).
    Can someone explain why the 12V on the output of the 7805 is observed in this case?[​IMG]
  2. chrisw1990
    Oct 22, 2011
    543
    41
    have you tried removing the diode?
    i have a feeling the reverse biasing might be why, dont quote me on it
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's because the impedance of your meter is so high. Any leakage at all through the diode, and you will see the battery potential at the regulator output; as without a ground path there is no load on the board.
    russpatterson likes this.
  4. mixed_signal
    Dec 5, 2009
    22
    The diode is to discharge the output of the regulator when the external supply is removed. If you reverse it, the diode will conduct in normal operation... not good! Then you'd raise the 5V rail up close to the input (12V??).
    -Scott
  5. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I suspect that without a gnd reference, your regulator has nothing to regulate voltage against. The ground pin will drift high (possibly quickly) and the regulator follows. Measure your return to battery negative and see if you don't get the same 12v.
