voltamp vs watts
Discussion in 'General Electronics Chat' started by Erin G., Mar 27, 2005.
  1. Erin G.
    Thread Starter Senior Member
    Mar 3, 2005
    167
    In a resistive circuit, voltamps and watts are equal, because the power factor is 1 (100%). In an inductive circuit, since the current lags the voltage, voltamps is generally higher than watts. In other words, apparent power is higher than actual, usable power.
    Is there an easy formula to convert voltamp ratings to amps in an inductive, non-transformer, circuit. Capacitve circuit?
  2. Erin G.
    Mar 3, 2005
    167
    Oops. double posted <_<
  3. David Bridgen
    Feb 10, 2005
    278
    Power factor = True power/Apparent power
    = W/VA
