voltage
Discussion in 'General Electronics Chat' started by joni, Oct 31, 2009.
  1. joni
    Oct 4, 2009
    39
    How I can to straight the voltage of 3 phase generator that his peaks give me 24 volt and 10 watt, the average velocity of the generator is 6000 rpm
    The generator don't give me a straight voltage
    The motor of the system is brushless 60 watt
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    You need to define a couple of things. Is the generator a 3 phase generator or an automotive alternator? Is the motor a brushless DC motor or an AC induction motor? Manufacturer and model numbers of each would help.
  3. joni
    Oct 4, 2009
    39
    Thank you BillB3857
    1. 3 phase generator
    2. brushless DC motor
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    What kind of controller are you using to drive the brushless DC motor? Typical drives take the AC input from the line or generator, convert it to DC then chop up the DC to generate the equivalent of 3 phase variable frequency AC. The magic behind this is constant communication (feedback) from special sensors in the motor to let the controller know the exact shaft position of the motor. Can you describe your project?
    Your original post talked about straight voltage. Do you mean Direct Current (DC). If so, you can rectify the three phases with 6 diodes set up as a three phase bridge.
  5. joni
    Oct 4, 2009
    39
    can you explain how to rectify the three phases with 6 diodesset up as a three phase bridge
  6. John P
    Oct 14, 2008
    1,637
    225
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    Now that JohnP has answered your question about how to build a 3 phase rectifier, how do you plan for the DC from it to run your brushless DC motor???
