voltage vs. current
Discussion in 'General Electronics Chat' started by PackratKing, Jul 27, 2008.
  1. PackratKing
    Jul 13, 2008
    850
    216
    It is my understanding [ possibly wrong ] that any electrical device, when supplied with its proper voltage, will only draw the current it needs to operate at peak design efficiency.
    Conversely, if supplied an over or under voltage, a device [motor] will promptly " release its magic smoke "
  2. studiot
    Nov 9, 2007
    5,005
    515
    Sorry,
    What's the question?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    In a car, all loads should be fused to prevent a fire if a wire gets shorted to ground in a crash.
    A current-limiter would get extremely hot: 12V x 20A= 240W of heat.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Perhaps they want to run a motor at a slower speed?
    Or perhaps they want to protect against a motor operating in a stall condition.
    A DC motor when running no-load generates back EMF that causes it to stabilize at a particular RPM. As the load on the motor increases, the RPM decreases as does the back EMF. If the motor is stalled, the current will be at maximum because there will be no back EMF.
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Depends on the 12 volt device... Many would not need one. Some might occasionally overload themselves.
  6. studiot
    Nov 9, 2007
    5,005
    515
    A car battery can, and does every time you start the engine, supply hundreds of amps.
    The starter motor is designed to accept this for short periods, but other additional devices eg a winch motor may well burn out if it pulls against to great a mechanical load.
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    Is that " 70 A battery" the rating in amp-hours or cold cranking amps. If it is amp-hours (which I suspect), the the battery can deliver far more than that if shorted. Thus another reason for protection. John
  8. yikes
    Member
    May 19, 2007
    11
    A DC motor when running no-load generates back EMF that causes it to stabilize at a particular RPM. As the load on the motor increases, the RPM decreases as does the back EMF. If the motor is stalled, the current will be at maximum because there will be no back EMF.[/QUOTE]
    Is there a system (method, circuit?) to use or eliminate the bemf?
  9. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    One could use a screwdriver to short the terminals, but doing so would be quite dangerous. Metaphorically, bemf is the electronic equivalent of Newton's reactive force. No bemf means no work being done, and all the input energy being wasted as heat.
    A current limiter would prevent this, but as noted by Audioguru, it would itself waste energy. Soft-start control would be more efficient, but more complex.
    PackRatKing: what is the device your friend wishes to protect?
