Voltage Transducer with AC Output
Discussion in 'General Electronics Chat' started by Dawud Beale, Jul 1, 2015.
  1. Dawud Beale
    Feb 10, 2012
    275
    7
    Hi, I am looking for a voltage transducer but they all seem to give RMS outputs. I am looking to produce a sine wave in labview from an AC mains input. Can anyone suggest anything or give feedback on how to find it without bringing up the RMS DC output transducers?
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    What you're looking for is called a "transformer" ;).
    Dawud Beale, #12 and cmartinez like this.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,703
    1,300
    A transducer is a physical device. Labview is a software program. I don't understand your question.
    ak
  4. MaxHeadRoom
    Jul 18, 2013
    10,858
    2,525
    Are you looking for something like an LVDT?
    Max.
  5. cmartinez
    Jan 17, 2007
    3,698
    2,792
    If I understood your question correctly... then I believe that Alec_t has given the right answer is post #2
    Dawud Beale likes this.
  6. #12
    Nov 30, 2010
    16,704
    7,354
    All sine waves have an RMS value like all empty boxes have cubic inches. It's merely a way to describe them.
  7. cmartinez
    Jan 17, 2007
    3,698
    2,792
    Yeah, I know... but I'm under the impression that the OP wants to see the mains sine wave in labview. For that, he'd need a transformer to scale down the voltage so it can be within the range of whatever probes or instrument he's planning to use to interface to labview
  8. #12
    Nov 30, 2010
    16,704
    7,354
    Did you think I was talking to you? I was not. I was explaining to the TS why all transducers of sine waves have an RMS description.
  9. cmartinez
    Jan 17, 2007
    3,698
    2,792
    oh... :confused:
  10. Dawud Beale
    Feb 10, 2012
    275
    7
    Hi guys, yes transformer did the trick. Thanks. Just to clarify, I am indeed looking to see a sin wave in lab view.
    Follow up question.
    If I am monitoring three phases of a three phase system, is each individual phase 230V?
    I understand that 3 phase systems are 415V but I am not sure how 3 lots of 230V give you 415V.
    To monitor each phase, do I need use a 230V rated transformer or a 415V transformer?
    What I don't understand, usually you only get voltage superposition when positive and negative terminals are connected together. If two positive terminals or two negative terminals are connected, you usually increase the available current draw rather than superimpose the voltages. Thats with DC. So how is 3 times 230V giving us 415V?
  11. #12
    Nov 30, 2010
    16,704
    7,354
    ten characters.
  12. Dawud Beale
    Feb 10, 2012
    275
    7
    So does it depend on the type of transformer? Is that the transformer within some equipment being powered by three phase or transformer that is part of the grid infrastructure external to the building?
