Voltage to frequency converter
Discussion in 'General Electronics Chat' started by pranav_shenoy, Feb 17, 2015.
  1. pranav_shenoy
    Feb 17, 2015
    12
    Can anyone send me circuit diagrams and working of voltage to frequency converter and frequency to voltage converter? Thank you in advance:)
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Look up the LM331 - the datasheet details how to use it in both configurations.
  3. Dodgydave
    Jun 22, 2012
    5,172
    778
    Lm2907 F to V chip.
  4. Shabbir_Ahmed
    Feb 17, 2015
    8
    Hi
    Voltage to frequency converter can also be called a voltage controlled oscillator.
    refer the wikipedia page for more details...................http://en.wikipedia.org/wiki/Voltage-controlled_oscillator
    or you can refer this link too for circuit diagrams..................http://circuitsplanet.blogspot.in/2015/02/voltage-controlled-oscillator.html
    for FVC...................................................................................http://circuitsplanet.blogspot.in/2015/02/frequency-to-voltage-converter.html
  5. ScottWang
    Aug 23, 2012
    4,936
    777
    I think you better talk some more what you want to do for that F to V then when the members give you the solution may easily to get to target.
  6. JWHassler
    Member
    Sep 25, 2013
    205
    34
    I'm with him.... the frequency-range that you need will have a huge impact on the topology/effort required
  7. Shabbir_Ahmed
    Feb 17, 2015
    8
    What range of frequency are you looking for?
  8. ian field
    Distinguished Member
    Oct 27, 2012
    4,464
    792
    If you want dead simple - just use the 2-transistor astable multivibrator.
    The 2 high value resistors that feed the transistor bases and form the R part of the CR timing networks usually go to Vcc in a fixed frequency implementation, You can also common those 2 resistors and take them to Vcc through a pot that can vary the frequency - or you can return the tops of those 2 resistors to a voltage that controls the frequency.
  9. ian field
    Oct 27, 2012
    4,464
    792
    The 331 is also equivalent to an RC145...something or other.
    Sharp made a version. AFAICR; "331" fits into their longer part number.
    These chips were all the rage in the early days of multisync VGA - I haven't checked whether any of them are still obtanium nowadays.
