What correlation does your current output need to be with the voltage output, and for what load resistance?
If your load resistance is high, it may be difficult/impossible to get a supply voltage high enough for the desired current. I=E/R.
You should post a schematic image (.png preferred) of your circuit as it exists now. This will help us to help you more quickly, as it eliminates a lot of questions.
