voltage to current converter
Discussion in 'The Projects Forum' started by chravikumar, Apr 17, 2006.
  1. chravikumar
    Apr 17, 2006
    Any one has the circuit of an A.C current source using opamps OP07 or LF356?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is a bit confusing. One can use an op amp to make an oscillator, but a current source implies some higher capacity. I don't think either device can supply more than 10 mills out the output pin - not much of a currebt source. Is this really what you are after?
