voltage to current conversion
Discussion in 'The Projects Forum' started by davinder02, Nov 14, 2008.
  1. davinder02
    Nov 14, 2008
    hi friends,
    i want to convert 1-10 vdc input signal to 4-20 mA output signal.Do anyone have the circuit for this.i have seen the ckt to convert 1-5 vdc input signal to 4-20 mA output signal.
    Any response would be appreciated.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    By examining the input resistors, it should be simple to make a scale change and use that circuit for your purpose. Or leave that unchanged and simply reduce your signal voltage by one half.
  3. mik3
    Feb 4, 2008
    4,846
    63
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    A voltage follower is ideal for this.
    eric
