Voltage Swing of Common Gate?
Discussion in 'Homework Help' started by micachu, Apr 30, 2015.
  1. micachu
    Oct 13, 2014
    15
    Hi, for a common gate amplifier circuit what determines the voltage swing? I've attached an image of a circuit.
  2. WBahn
    Mar 31, 2012
    18,089
    4,917
    Show your attempt to analyze the circuit in an effort to answer the question.
  3. micachu
    Oct 13, 2014
    15
    20150430_154651.jpg Would the voltage swing be across Rd?
  4. WBahn
    Mar 31, 2012
    18,089
    4,917
    The voltage swing, unless otherwise specified, normally refers to whatever is considered the "output". I would image that in this case it is referring to the voltage across R5, which I'm assuming is an AC-coupled load.
