I am working on an automotive project and need to convert a voltage range of 22V to 28V down to a voltage range of 500mV to 5V to interface with the vehicle's controller.
I've come up with a transistor design but only supplies a variation of around 1V over that range from 3V to 4V, which I believe to be too low a resolution.
I am also trying to ensure that if a fault occurs, the input of the vehicle's controller will never see anything more than 5V as the maximum input voltage is 5V.
Any suggestions or guidance in the right direction?
