Voltage spike
Discussion in 'General Electronics Chat' started by Webby, Aug 11, 2008.
  1. Webby
    Thread Starter Active Member
    Jun 15, 2008
    66
    Hi, when a magnetic field collapses a voltage spike is induced what is meant by "CEMF". Bit confused I know its something to do with "Electromotive Force.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    CEMF stands for Counter ElectroMotive Force. The voltage induced by the field in the inductor will have a polarity opposite to the applied voltage.
  3. Webby
    Jun 15, 2008
    66
    Thanks for that do you mean then the induced voltage spike will flow in a different direction to the applied voltage?
    Is "Back EMF" the same as "Counter EMF"?
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    Plus, the voltage of the back EMF or CEMF will be proportional to the resistance of the circuit in parallel with the inductor, when the voltage applied ceases to exist.
