Voltage specs for LED
SPQR
Joined Nov 4, 2011
379
Hello all - simple question.
Recently I purchased THIS 7 segment LED display.
The company stated that the forward voltage was 1.8V.
Connected to output pins of an Arduino at 4.8V, the segments were all nice and bright.
I didn't believe the manufacturer's 1.8V spec so I used my simplistic power supply and made this Voltage/Current curve.
I'm happy to report that the manufacturer's specs are correct!:)
1.8V at 10mA gives a nice bright LED.
Questions:
1 - Why would an LED be manufactured for such a low voltage when CMOS and TTL are 3.3 and 5V respectively?
2 - Can I treat these just like any LED, use 5V and a 1k resistor to limit the current to 10mA?
Again, I thank you in advance.
30,810
No LED should be connected to a voltage source without proper current limiting resistor or circuitry, which includes constant current sources and PWM circuits.
THE_RB
Joined Feb 11, 2008
5,438
Questions:
The forward voltage of the LED diode is determined by it's chemical makeup in the silicon doping. That means it's colour, so a red LED will have a low forward voltage while a blue LED has a much higher forward voltage. They simply can't help that, it's the way the diode is.
Yes, and as MrChips said it very important to use a resistor to limit the current to a safe value!
Normally with a 7 segment display the common pin is driven hard (no resistor) and the 7 or 8 pins for the segments each have their own resistor, as each segment is an individual LED.
There are some different ways of doing it, but as a general rule that is the best way.
You should probably have a google around for "7 segment display driving" and look at all the ways this is done. :)
SPQR
Joined Nov 4, 2011
379
Excellent answers.
I had gotten that feeling in a variety of posts over the last few months.
It's good to see it written in perfect clarity.
Interesting about the different voltage requirements as a function of color (doping).
I've many different types of LED - perhaps I'll take some time and do more of the V/I curves.
And I thank you for the electrical jargon - "driven hard" - it's good to know colloquialisms in any language.:)
Again, thank you both for your answers.
