Shown in the attachments is a circuit with the ground given, I hope I converted it to the second circuit correctly with the ground in the correct location of the circuit. I would like to know what the voltage across the resistor is?
Since the ground is there I would assume 0V. If ground wasn't labeled, I would choose 5V. Which voltage is correct with ground there?
Thanks!
Thanks!
