what happens if a voltage source with resistor are being short circuited I will give a concrete example
I would say the voltage Uab in this case is equal to zero ,because the potential between the two points A and B is equal to zero, and the voltage source is parallel to it , so its also equal to zero. I even tried to do source transformation and i got that the current is equal to zero . what I did is right ?
what im interested in in the voltage between A and B or thec current between A and B
