voltage scaling
hardik vamja
Joined Oct 15, 2015
13
Hi I need to convert 3.7 to 4.7 volt into 1 to 5 volt
I know it can be done with opamp but I don't have any idea what can I do in this
Plz any one can help me..!!!
34,432
What supply voltages do you have?
What is the output load?
How accurate does the shift need to be?
hardik vamja
Joined Oct 15, 2015
13
Actually I'm converting RTD resistance into 4to20 ma current and output of bridged & instrumentation amplifier is 3.7 to 4.7 volts so I need 1 to 5 that can easily converted into 4-20ma
My power supply will be 30v(+15 -15) to opamp
MikeML
5,444
So what is the RTD min and max resistance over your range of interest? There may be a way of doing it more directly.
Joined Nov 30, 2010
18,224
this must be very precise.
May I suggest using fixed resistors to make a trim pot work in a small range of voltages. That's one way to get a more accurate voltage setting.
For instance, if you're trying to get 4.6V out of a 5V supply, put a 4.7 k resistor under a 1 k pot. That way the pot works from 4.1 volt to 5 volts.;)
MikeML
5,444
Yeah, but if the 5V supply drifts from 5.000 to 5.050 (1% change), the output of the scaling opamp shifts 3%, i.e., it is ratiometric. In the OP's case, he is likely trying to get 4.600V from his +15V supply. How stable is that?
In any case, I would use a voltage divider, followed by an opamp voltage-follower to drive the left end of R1 (see post #4). Or use a real voltage reference like (wait for it) TL431 to make the 4.600V.
MikeML
5,444
Try this for a relatively stable adjustable voltage reference.
If you keep the instrumentation amplifier, you will need a stable voltage reference for it, too...
