Voltage/resistance to 4-20mA
Discussion in 'The Projects Forum' started by cts_casemod, Oct 3, 2013.
  1. cts_casemod
    May 14, 2013
    35
    I am trying to build a circuit to convert a voltage into a 4 - 20mA signal
    Basically I have a POT in which the voltage divider provides between 0.8 and 4.6V from a 5V supply (or 1.2 to 2.2KOhm impedance) and I want to convert that into a 4 - 20mA signal.
    Any advice?
    PS: No my pot wont go all the way down to zero.
    Range of values is 1230 to 2200Ohm.
    Many Thanks
  2. moot
    Member
    Sep 20, 2009
    46
    A resistor is the simplest voltage-to-current device. You should be able to convert 5V into a 4-20mA current with a 250-1250Ω potentiometer (i.e. variable resistor), and nothing else. Do you have a guess at what such a circuit would look like? Remember, V = IR...
  3. wayneh
    Sep 9, 2010
    12,388
    3,244
    I built a voltmeter using a 4-20mA panel meter. It used one op-amp for the offset (4mA at 0V) and a second op-amp to operate as constant current loop driver, with the current proportional to an input voltage.
  4. cts_casemod
    May 14, 2013
    35
    My particular pot has a range of values between 1250 and 2200Ohms.
    Remember, V = IR...? It wont work without a converter of some kind
  5. cts_casemod
    May 14, 2013
    35
    That might be what I am looking for. Do you have a schematic?
  6. moot
    Member
    Sep 20, 2009
    46
    Sorry I read 2200Ohms as 220Ohms. Had that been the case, just putting the pot in series with the 5V would give you the proper conversion. (There's a nice discussion of passive V-to-I concepts here. The problem with a passive converter, of course, is that the output depends on the load.)
    Here is an app note from apex about V-to-I conversion with op amps, with circuit ideas.
  7. wayneh
    Sep 9, 2010
    12,388
    3,244
  8. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Here's a very simple circuit which gives ~3.6mA-20.5mA for a 0.8-4.6V input. Close enough?
  9. cts_casemod
    May 14, 2013
    35
    Even so, it wouldn't work. I need an active converter because any voltage drop over the line needs to be compensated to archive the same current. Thats one of the many advantages of using a 4-20mA signal.
    I might do it with an op-amp, seems good enough to have a go :cool:
  10. moot
    Member
    Sep 20, 2009
    46
    Yes, as I said, a passive V-to-I converter has several problems, including being load-dependent. Have you tried the circuits suggested by Alec_t or wayneh?
    If you don't have a transistor (but if you do have lots of op amps), you could also try the attached circuit. It's a current source I found here, plus a current mirror (from the app note I linked to earlier) to amplify the current 50x. But there is a problem with it: it doesn't give you your whole range. You could get by this by finding/buying a 2k pot, or using a switch with a resistor in parallel to R1 to perhaps double the range. (Note, I haven't tested or simulated this circuit. It's just another option to try.)
  11. cts_casemod
    May 14, 2013
    35
    Yes. I tried alec circuit but it does not seem to be stable at 5V-6V.
    Works fine at 12V.
    I am trying something a bit different. Ill post results soon
  12. Alec_t
    Sep 17, 2013
    5,973
    1,135
    I wouldn't expect it to work well with a 5V supply using the LM324, as it's max output is ~ 1.5V less than the supply voltage, i.e. only 3.5V with the 5V supply. That's why I suggested a higher supply voltage. Or you could use a different opamp.
    cts_casemod likes this.
  13. cts_casemod
    May 14, 2013
    35
    Yes, Thank you!
    I used an LM2904 and an 2N3904 Transistor with a base resistor of 1.8KOhm.
    Yes, 5V to have 20mA in the 220 Ohm resistor I used, plus the losses on the comparator internal transistor and the external NPN transistor, so about 7.5V.
    The passive isolated transducer takes another 5V to supply the internal electronics @ 20mA output
    All working now!!
  14. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Nice to know it works for you.
