I'm still not comfortable will the circuits with negative voltages. I need to go through this again!
It still has to follow Kirchoffs voltage Law around the loop, the sum of the voltage drops equaling zero . Vz + Vbe + Vload = 0. -8.2 + 0.7 + 7.5 = 0I'm still not comfortable will the circuits with negative voltages. I need to go through this again!
Yeah finally I got the whole picture after a friend of mine in IRC has helped me!Do the same calculation for the positive regulator. The signs are the same.
V(z)-Vbe-Vrl=0
This equation is the same for all cases. Only the signs are replaced. It is a sign of V (z) and the sign of Vbe.
Thread starter | Similar threads | Forum | Replies | Date |
Problem in Combining Two Voltage Regulators (AMS1117 3.3) (LM7809) | Power Electronics | 10 | ||
Voltage Regulators - Problem 5 | Homework Help | 6 | ||
Voltage Regulators - Problem 4.b | Homework Help | 25 | ||
Voltage Regulators - Problem 4.a | Homework Help | 30 | ||
Voltage Regulators - Problem 3 | Homework Help | 70 |
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Duane Benson
