Voltage Regulator
Discussion in 'General Electronics Chat' started by Vinny_P, Jan 27, 2008.
  1. Vinny_P
    Jan 27, 2008
    Hey all,
    I have a circuit that has 11.15VDC offset which I would like to remove. The circuit is solely DC (no AC component). Someone told me I can use a voltage regulator to remove the offset therefore my read out will be between 0 - 5VDC. Can someone please shed some light on this issue.
    I was thinking of using the summing opamp circuit to remove the offset. But the voltage regualtor method is interesting to me.
    Furthermore, I was also thinking of having a zener diode with a avalanche voltage of 11.15V in series with a resistor and have the read out on the resistor.
    Thank you,
    Vinny P
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Do you have a schematic that you could post?
    .jpg or .png would be the preferred format.
  3. scubasteve_911
    Dec 27, 2007
    1,202
    You cannot use a typical linear regulator, since it is designed for a specific output voltage. If it were a 5V regulator, then it will not behave correctly below 5V+dropout.
    It really depends on what you are driving with your intended 0-5V signal. If it is a very high impedance load, then you can use a simple voltage divider to scale your 11.15V down. If you need to drive more of a load, then you can add a voltage follower. Furthermore, if you don't want to use a voltage divider, you can set up two inverting amplifiers to give the needed gain to convert your 11.15V down to 5V. This would be a good route if your signal has a very high source impedance and if you have a bipolar supply.
    Steve
  4. Vinny_P
    Jan 27, 2008
    I'm using a AD590 which will produce the current accross a load Resistor that will give the input to the ADC of an MCU.
    The load accross the resistor will vary from 11.15VDC to 16.15VDC but I want it to be from 0-5VDC.
    I simply want to remove the 11.15VDC offset. I beleive using an opamp it is possible (suming sircuit). However, someone did mention a voltage regualtor would be a good alternative.
    Secondly I can't have a voltage divider on the 11.15VDC as I want to eliminate it completly.
    Hope some one can help,
    Vinny P
    The following images may help.
    http://img299.imageshack.us/my.php?image=2301082317qn7.jpg
    http://img180.imageshack.us/my.php?image=2301082316nf6.jpg
  5. KMoffett
    Dec 19, 2007
    2,584
    234
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  7. Vinny_P
    Jan 27, 2008
    Hey Guys,
    I decided to use the difference amp with unity gain utilizing the LM317L op amp due to budget reasons.
    Will let you know how it went. :)
    Thank you all... it is much appreciated,
    Vinny P
