Voltage regulator
Discussion in 'General Electronics Chat' started by sabbar2006, Jan 26, 2008.
  1. sabbar2006
    Jan 26, 2008
    thank you
    this the first time i write to you
    please
    i want from u a complete general circuit diagram of automatic voltage regulator AVR because i want it in my project
    please sent it to me to my email sabbarjan@yahoo.com
    thank you
    yours
    sabbar
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    We don't usually do circuits on demand! We can help you but don't count on us to do the whole thing. And we usually don't e-mail either.
    So, post what you've done so far. Post a circuit diagram and be as specific as you can. Write one page about the problem if you have to. We will gladly help if you do that.
    The same here. However, I might add two points:
    - You should have read the previous replies on how this forum works (you just repeated preye2007's mistake), so this could have been avoided;
    - You shouldn't hijack someone else's thread in order to solve your own problem.
    By the way, is it really the first time? Or is it the second time? :confused:
    Nevertheless, if you think I'm being impolite, then you should really double-check your requests. Really, normally I'm very polite and welcoming, but given the circumstances...
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Placing your question in an existing thread is called hijacking, and is discouraged.
    What work have you done? Look up the data sheet for a 7805.
