I would like some help with designing a voltage regulator. I am not very good at electronics as my background is in Mechanical.
But what I would like to do is:
Design a Voltage Regulator that can output a voltage of around ≈13.5v DC
The input voltage is from ≈13.4v to 16.4v DC (continuity changes between that voltage range)
The Ah ≈ 90Ah to 150Ah
(not 100% sure on this. (so should the circuit be designed to handle 150Ah even is the Ah turn out to be 90Ah in the end?)
