voltage regulator
Discussion in 'General Electronics Chat' started by isha, Oct 28, 2005.
  1. isha
    Thread Starter Active Member
    Sep 16, 2005
    36
    consider a circuit in which power supply voltage is of +12V
    a zener diode [Vz=9.1V] is connected to power supply through a resistance of 100ohms
    Izk=5mA, load current can vary from 0mA to 15mA
    when we connect a load resistance of 100ohms across zenerdiode then diode is drop out of the circuit and voltage drop across RL become 6Volts
    Can we design voltage regulater circuit using zener diode such that when we connect load of 100ohms,its voltage drop remains 9 volt , i.e;zener diode operates normally???????
