I am wanting to build a voltage regulator with current limiting of 1 Amp.
The output must be 1.2Amps at 13.8 Amps. The input voltage is the tricky one.
Under normal conditions its input voltage is 26 Volts DC but can spike to around 60 Volts under certain conditions.
I was considering the L200 but don't understand a few things.
Firstly I don't want the voltage to ever go above 13.8 volts on the output or the 1.2 Amps.
I also want to protect the input voltage so the unit is not going to be damaged. I was thinking of putting an MOV and a resettable fuse. On the input.
I would value some guidance here.
