Voltage Regulator Tester VRC101-B
Discussion in 'General Electronics Chat' started by mejdi_electronique, Mar 6, 2007.
  1. mejdi_electronique
    Mar 6, 2007
    Hello i'm a tunisian student and i have a project to improve this tester
    plz anyone can help me
    Features:
    • Test A and B Type Circuit Alternator Regulators
    • Test 12V, 24V, and 32V Alternator Regulators
    • Test Field Circuit with 0.5A, 3.0A, or 5.0A Load
    • Identify Active L-Terminal (Choke Drive)
    • Identify Presence of Over-Voltage Function
    • Identify Presence of Field Diode
    • Warning Light Circuit to Simulate Vehicle Indicator Lamp
    • Short Circuit Lamp to indicate Regulator Short Circuit Overload
    • Stator Output Signal for Testing Delco CS-Series and Other Types with this
    Requirement
    • Lead Set and Test Manual Provided
    OPERATING INSTRUCTIONS FOR VRC1000
    1. Set the field current switch to 0.5A for checking or setting the
    regulation voltage. Set the field current switch to 3A for burn-in.
    2. Set the "FIELD" switch to "A" or "B" according to the tester
    information given on the tester instructions.
    "A" Circuit - The "A" circuit regulator design has one alternator
    field lead connected to battery (or trio) and the other end of the
    field is controlled or switched to ground by the regulator.
    "B" Circuit - The "B" circuit regulator design has one alternator
    field lead connected to ground and the other field is controlled or
    switched to the battery (or trio) by the regulator.
    3. Connect test leads according to tester instructions for the
    regulator being tested and follow all information given by notes
    and additional tests when applicable.
    4. Select the "Voltage Range" (12v, 24V, and 32V) for the regulator
    being tested and turn the power switch to the "ON" position.
    5. If the short circuit light comes on, quickly turn the tester "OFF".
    The short circuit light indicates that battery positive is being
    shorted to battery negative. However, when testing some vibrator
    contact regulators such as Ford GRB-5440 or Delco 1119519, the
    short circuit light will come on which is alright if the field
    light blinks. However, do not test the vibrator contact regulators
    longer that two minutes. Should the tester fail due to overload,
    check the fuse. The Transpo VRC1000 is not to be used to check D.C.
    generator regulators. The tester is designed to be used to test
    alternator regulators only.
    TEST RESULTS "GOOD REGULATOR"
    The regulator is operating correctly if the field light blinks and
    the digital meter displays approximately the set point voltage
    given on the appropriate tester instructions. Sometimes it may be
    necessary to adjust the voltage setting on those regulators that
    are adjustable. See the tester instructions for the regulator being
    tested.
    TEST RESULTS "BAD REGULATOR"
    Full Field - The digital meter will indicate approximately 16.5V
    for a 12V regulator, 29.5V for a 24V regulator and 42V for a 32V
    regulator. The field light will not blink but will remain "ON".
    A regulator with this type of defect will not be able to control
    the output voltage of the alternator
    javivid24 likes this.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What is it about the product you desire to improve?
    hgmjr
  3. mejdi_electronique
    Mar 6, 2007
    I want that this tester is programmable and I does not know the good composing to modify this tester .
    and I want that the bill-poster indicates a text .
    thanks
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    What are you referring to when you use the term "bill-poster"? I am unfamiliar with that term.
    hgmjr
  5. javivid24
    Jan 10, 2012
    where can I buy one like this?, I need any option to buy a vrc 101 b
