voltage regulator sot23-5 active low enable
Discussion in 'General Electronics Chat' started by aamirusaf, Jun 12, 2012.
  1. aamirusaf
    Jun 12, 2012
    Hi folks,
    I have made a mistake in my pcb design by connecting (active high) enable pin (pin 3) of voltage regulator TLV702xxDBV (SOT23-5, 2.8V output, 300mA) to ground . This has disabled the output permanently.
    Can someone here help me in finding a voltage regulator with active low enable pin. I have found one tps79028 but this one is only able to supply 50 mA. I need a regulator that can deliver atleast 200 mA.
    Can some give clue.
    Best Regards,
  2. JMac3108
    Aug 16, 2010
    349
    66
    You can always resort to lifting the pin on the SOT-23 and connecting it high with a short jumper wire. Or put a small piece of Kapton tape over the PCB pad before soldering down the part so that this pin does not make connection to the PCB. Then connect it properly with a jumper wire.
  3. aamirusaf
    Jun 12, 2012
    thanks Mac, I already did that with one board. I was just wondering if I can avoid such mess on the other.
