Voltage Regulator not working
RodneyB
Joined Apr 28, 2012
697
I have made this regulator as per the attached drawing and data sheet.
When I applied power the voltage was the same as the input as I increased the input so did the out put it never was at the 12 volts I thought it would regulate at,
Any assistance would be greatly appreciated
RodneyB
Joined Apr 28, 2012
697
My sincere apologies I made a really stupid mistake, I connected the Input to the output. Swopped the wires around and all good.
ericgibbs
Joined Jan 29, 2010
18,862
hi Rodney,
It should work OK, a common error is having the Pinout the wrong way around, double check, post a photo if possible.
E
EDIT: You posted back at the same time as me.;)
