Hi All
I know this is very basic stuff but any help would be appreciated. I need to spec a voltage regulator chip and a mosfet. I'm running off a 18650 Lithium battery and can get surges of 20A (at least that is what I'm told). The voltage regulator will have input of 3.7V and output of 3V. The output will be used to bias the mosfet and run a 555 chip for a pwm.
So when I look at voltage regulators which value do I check to make sure I won't fry the chip? Same with the mosfet, it will be handling 3.7 V at about 6A but might see a 20A surge. Which datasheet value do I need to check to make sure I'm ok.
thanks much
thanks much
