voltage regulator LM 723 ?
Discussion in 'General Electronics Chat' started by logmode, Sep 11, 2011.
  1. logmode
    Sep 5, 2011
    48
    Input 24 vac, throw full rectifier with 1000 UF capacitor. Achieved 7 to 30 vdc output. Used less than a 2 watt load for the test.
    I have never built a circuit board before. I am focusing on the regulator. I found this schematic and built it. It works, and then I studied it. It seems that the voltage regulator watches terminal #4 voltages input, mine is 7 Volts. If the voltage drops at terminal #4, the regulator increases voltage out terminal #10 until 7 volts is found again at terminal #4. Is this correct?
    Thank you
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
