Voltage regulator help
Discussion in 'Homework Help' started by droggie, Oct 24, 2012.
  1. droggie
    Oct 21, 2012
    137
    I'm running a 12 V LED with a 9 V battery for experimental purposes. I have a 12 V "fixed" voltage regulator. Is this device appropriate for what I am doing? Or should I be using a higher voltage for the LED with the regulator? It gets really hot, is this because I am using a lower voltage than 12V?
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Do you have the specifications of the led?
    A datasheet or a link to it would help.
    Bertus
  3. droggie
    Oct 21, 2012
    137
    I do not. It is just a 12 V led. Could it be possible that the 12 v regulator is making the 9 v work twice as hard to produce the regulated 12 v voltage?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Nobody makes a "12V LED".
    A red LED is about 2V, an old yellow or green LED is 2.2V and a white, blue or new green LED is about 3.5V. A few LEDs can be connected in series and in series with a current-limiting resistor and powered from 12V.
    An LED needs to have a current-limiting resistor in series. Then if the resistor is calculated properly the LED and resistor can work from 12V. An ordinary 5mm LED should never be hot.
    Since you did not attach a schematic then we do not know what you are doing with a 12V regulator and a 9V battery. The schematic should show the part number of the 12V regulator.
    You said "it" gets hot. What gets hot, the LED, the 12V regulator or the 9V battery?
  5. droggie
    Oct 21, 2012
    137
    The regulator gets hot.
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The regulator will get hot if you connect its pins wrong or if the important input and output capacitors are missing. Please attach your schematic.
    Maybe you used a 7812 voltage regulator. Its minimum input voltage is 14V but 14.5V and higher is recommended. A 9V battery can power a 7805 5V regulator until the battery voltage drops below 7V.
    A voltage regulator does not boost the voltage.
  7. droggie
    Oct 21, 2012
    137
    I do not have a schematic, but I have attached some more pictures. When I remove the regulator, the speed of the fan increases. So I'. guessing the regulator is functioning well. It's just my multi metre shows 2 v when I touch the wires of the fan. It is probably just a connection error. One more question, if I add more regulators in serious with the reduced voltage double? i.e two 12v fixed regulators will reduce a 12v device it to 6v?
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    Where are your "attached" pictures?
    If a 12V regulator has an input that is at least 14V then its output is 12V if the load current is 1A or less. Its output is regulated at 12V so it should not drop if it is not overloaded.
    We do not know if the input voltage to your 12V regulator drops below 14V when you connect the fan. Measure it and tell us.
    You should learn how to draw or copy schematics. I use Microsoft Paint program to copy and modify schematics and parts of schematics.
  9. droggie
    Oct 21, 2012
    137
    Sorry, here I have posted the pictures.
  10. droggie
    Oct 21, 2012
    137
    The input voltage would be 18v
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    The important input and output capacitors are missing. They are shown on the datasheet.
    The regulator gets hot because it is missing a heatsink.
  12. droggie
    Oct 21, 2012
    137
    How do I know which ends on the capacitors to connect to the regulator?
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    Ceramic and film capacitors are not polarized. Use ceramic capacitors at the regulator.
    Electrolytic capacitors have a black bar on the case beside the negative wire (many years ago the case was marked with a + beside the positive wire).
  14. droggie
    Oct 21, 2012
    137
    I can't use electrolytic?
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    I have never seen a 0.33uF or 0.1uF electrolytic capacitor.
    An electrolytic capacitor is used for low audio frequencies or to filter rectified mains (120Hz) with a value more than 2.2uF up to thousands of uF.
    A ceramic capacitor is good for filtering away high frequencies where a regulator might oscillate.
    A film capacitor is good for coupling audio and is good up to medium frequencies.
  16. droggie
    Oct 21, 2012
    137
    I have some .01 and 1uf ceramic capacitors. Can I use them or another variable? Because I do not have any .03 capacitors. And when connecting the capacitor to the voltage regulator do I connect one end to the input and the other end to the output? And finally, should I connect anything to the ground of the regulator? If so, where?
  17. Audioguru
    Dec 20, 2007
    9,411
    896
    0.01uF is too small. The 1uF ceramic capacitor will be fine for the input or output (or both) capacitor.
    Nobody said to use 0.03uF. The datasheet and I say the input capacitor should be a 0.33uF ceramic capacitor. They are cheap and common. Buy one and use it.
    No.
    In my post #11 I copied the schematic from the datasheet. It shows the center pin (common) of the regulator connected to ground and the input and output capacitors also connected to ground. There is no capacitor connected from input to output.
    The datasheet of the regulator shows a sketch of which pin is which. The schematic I copied from the datasheet in my post #11 shows the center pin (common) connected to ground. The input and output capacitors are connected to the common pin. The input ground and output ground are also connected to the common pin.
  18. droggie
    Oct 21, 2012
    137
    I have attempted to build it on a breadboard and have it pictured. Could you tell me if my connections are correct? Now there is either no voltage or very little.
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    The output capacitor marked "101" is only 0.0001uF (100pF) which is much too small.
    I cannot see the marking on the input capacitor.
    BOTH CAPACITORS ARE NOT CONNECTED TO GROUND, instead each capacitor is shorted.
    The center pin of the regulator is its ground pin but you have it connected to nothing.
    What is the black wire?
    What is the red wire?
  20. droggie
    Oct 21, 2012
    137
    Red is positive, purple is negative. I have posted clearer pictures. But I'm still confused on connect the capacitors. I cannot connect both to ground can I? Do I connect the input to ground and connect the output the same way I did before?
