voltage regulator for USB power
Discussion in 'The Projects Forum' started by yuhao, Dec 28, 2015.
  1. yuhao
    Dec 28, 2015
    Hi everyone, I am trying to build a power supply from a set of resonator circuit. The circuit can provide 8W for a 43 ohms load at 19V. I want to charge my phone (5V, 1A, 5W) with it so I use a voltage regulator (LT1375). But when I connect it to my circuit, the voltage output become very low (50 mV).
    Any advice would be very helpful. Below is the resonator circuit to supply power (replace the source in voltage regulator circuit) and the voltage regulator circuit (replace the load in the resonator circuit).
      File size:
      80.4 KB
      14
      File size:
      100.8 KB
      13
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    Are you saying that the circuit was tested and shown to be able to perform?
    This sounds like an error in wiring. Perhaps a short or the pin out was wrong. With a fuse in place, you could try a know good power supply such as a car battery.
  3. yuhao
    Dec 28, 2015
    Thank you for the reply!
    It is simulated in LTspice, and show to provide 8W.
    The regulator works well in LTspice when connected to a ideal source, but not to my resonantor circuit.
  4. Colin55
    Member
    Aug 27, 2015
    204
    21
    If you like LTSpice so much,just use the output from LTSpice and you will have 1 amp.
  5. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    The resonator can put out 8 W at 19 V. That's about 400 ma.
    The load is set to draw an amp, right?
    That may be your mismatch. Try decreasing the load current and see what happens.
  6. yuhao
    Dec 28, 2015
    Thanks for the reply.
    1) It does not work with even lower current such as 250 ma (e.g. change load to 2.5 ohms)
    2) There is a input of 8 W 19V, and I want a output of 5 W 5V, I thought there must be some way of using buck converter to achieve this ?
  7. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    Just to be clear, we're talking about an actual circuit, right, not a simulator?
    If so, you want to try *decreasing* the load current by *increasing* the load resistance. Don't drop the load resistor to 2.5 ohms, raise it to 50 ohms, and see what happens.
  8. Colin55
    Member
    Aug 27, 2015
    204
    21
    No-one has asked what voltage is the SUPPLY
  9. ronv
    Nov 12, 2008
    3,392
    1,449
    From the simulation:
    30 volt 205Khz sine wave.
    Bet that makes the problem clear to you now. :rolleyes:
  10. ronv
    Nov 12, 2008
    3,392
    1,449
    To get lower current you would need a larger resistor - maybe 10 ohms.
    To ask again. Is it the actual circuit that does not work or is it the simulation that does not work.
    If it is the circuit. What is the voltage going into the regulator when it fails.
    Things it might be:
    1- The coupling between the coils may not be as good as you have shown.
    2- The actual components may not be resonant at 205Khz because of tolerances.
  11. wayneh
    Sep 9, 2010
    12,368
    3,224
    OK, so this is all in simulation so far. Both circuits appear to work separately in simulation but fail when connected to each other.
    What does the voltage out of the resonator look like when the load is placed on it? It has an AC component? What are the peak voltages, high and low?
  12. ronv
    Nov 12, 2008
    3,392
    1,449
    Why so many stages?
  13. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I don't believe your resonator power calculation.
  14. wayneh
    Sep 9, 2010
    12,368
    3,224
    I wonder if he determined that it's drawing that much power. Seems unlikely it could deliver.
