New to these forums, but I was wondering if you guys could help me with a project. I'm not the most experienced with electronics, so bear with me, but I have an electric motor that usually would be powered by a 7-8v source, and I wish to use a readily available 12v source to power this motor. A straight 12v to this motor probably wouldn't be a good idea, so I would like to lower the 12v to around 8v. One thing to keep in mind is that this motor will see different loads and current will be varying from 1A up to 40+amps. So what kind of circuit can I use? Are there any inexpensive solutions? I appreciate any suggestions, thanks!
