Voltage regulator for mains power supply
Discussion in 'The Projects Forum' started by mahela007, Sep 14, 2011.
  1. mahela007
    Thread Starter Active Member
    Jul 25, 2008
    45
    What are the types of voltage regulator circuits that can be used to regulate voltages in the range of 200 - 240 Volts? I need a circuit that will prevent the voltage from exceeding a value of about 210 volts.
    I'm not sure if a simple clipper circuit will work in this instance. Is there a way to adapt one for this voltage range?
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    multi tap transformers. Although not 'regulators', you can select your voltage within some percentage to accomodate your requirements.
  3. mahela007
    Jul 25, 2008
    45
    Are those expensive? If so, is there any electronic (semiconductor based) method I can use?
  4. MrChips
    Oct 2, 2009
    12,636
    3,454
    Constant voltage transformers.
  5. wayneh
    Sep 9, 2010
    12,388
    3,245
    I think mains-connected semiconductors would be a prohibited topic here anyway.
  6. #12
    Nov 30, 2010
    16,703
    7,341
    Big transformers are expensive, but you didn't say if you need 100 amps or 100 milliamps.
  7. mahela007
    Jul 25, 2008
    45
    I need very small currents.. just enough to charge a 330 uF capacitor in say.. 10 seconds..
