I have a power supply that is damaging devices that I am trying to measure. I hooked up a scope, and see there is a 0.6V spike when the meter becomes ungrounded which is damaging devices. I need to some how filter out that transient. I have designed and simulated a few circuits, simple zener diode with resistor regulator. Also a shunt regulator using a bjt. The problem is that the load resistance isn't in the same range everytime. Some devices are a few ohms, and some are around 150 and then values in between. The circuits I have made I can design to work for lets say 150, but if the load resistance changes to say 2, then the voltage across it is way to low. The devices are biased at 125mV. Anyone have any thoughts suggestions on how I can do this, what type of circuit would work best? Thanks a lot for your help!!
