Voltage regulator 9 volt phone charger voltage and amp output
Discussion in 'General Electronics Chat' started by dante_clericuzzio, Jun 17, 2016.
  1. dante_clericuzzio
    Mar 28, 2016
    68
    Using the circuit above provided by ISB123...i made a phone charger but instead of providing 1 amp that i've expected it only provide around 0.12 amp and 4.1 volt...is this normal and how to increase the amp i was thinking if the phone need 1 Amp it should draw 1 Amp from the battery...maybe there is a mistake or something...and it takes only 4 minutes to drain out until 0.08 amp
  2. AlbertHall
    Jun 4, 2014
    2,262
    448
    If your 9V battery is the standard PP3 kind, then that is your problem. Such batteries will not source 1A. Try measuring the battery voltage while the charger is connected.
  3. dante_clericuzzio
    Mar 28, 2016
    68
    What is standard PP3 kind? sorry i am completely no idea about this...the battery voltage has drop around 8 volt to 7.7 volt
  4. AlbertHall
    Jun 4, 2014
    2,262
    448
  5. Dodgydave
    Jun 22, 2012
    5,150
    769
    Use a better battery like a lithium or sla type.
  6. dante_clericuzzio
    Mar 28, 2016
    68
