heres a question...
A 75KVA transformer, rated at 11000v/230v on no load, requires 310v across the primary to circulate full-load currents on short-circuit, the power being absorbed being 1.6KW. determine:
(a) the percentage voltage regulation
(b) the full load secondary terminal voltage for power factors of (i) Unity
(ii) 0.8 lagging & (iii) 0.8 leading
I can do (b) if i new (a)
Do I 1st find Re and Xe from the full load current I1 and 75KVA and 1.6KW load also the cosθ then use the voltage regulation equation... is that how I go about solving this one??? I'm not sure how to get the 310v either??? any thoughts...
thanks...
thanks...
